Search
Search
Services
Products
Control & Safety Systems
IIoT & Digital Transformation
Industries
Chemical
Food and Beverage
Industrial Energy
Life Sciences
Oil & Gas
Power
Refining
Other Industries
Women in STEM
Events
Nashville 2019
San Antonio 2018
The Hague 2018
China
Russia
Products
Safety Instrumented Systems Blog
Fired Heater Safety Standards and Burner Management
Forums
Blogs
Library/Resources
Members
Tags
Jim Cahill
2 Apr 2013
Nikki Bishop
reformer unit
IEC 61511
Dave Sheppard
Refining
hydrocracker
fired heater
safety instrumented function
Safety
NFPA 86
burner management
safety instrumented system
API RP 556
refinery
Options
In an earlier post, Safety System Considerations for Process Fired Heaters, I highlighted an American Fuel & Petrochemical Manufacturers (AFPM) paper by Emerson’s Nikki Bishop and Dave Sheppard. In this post, I’ll share the safety system design, selection and estimated savings in startup time reductions from the paper. The authors note that safety instrumented systems [...]
SteveWJ
In your design of Natural Gas Fired Heater Burner Management System what would you consider the Pre Ignition Interlocks needed for Safe Burner light Off starting with the most important one first?
26 Jan 2022
Jim Cahill
Hi Steve, Here's some feedback I received. "Assuming the fired heater is greater than 12,500,000 Btu/hr, I would recommend looking at NFPA 87, specifically chapter 8 which would deal with the safety equipment and its application to the fluid heater heating system. That chapter lays out what is required and what is recommended for the BMS. I can go through and list the interlocks it calls out, but without knowing what the system looks like, I’d be listing items that may or may not be applicable. As to what would be the most important, that’s a bit like asking what your favorite brick in a wall would be. They all are equally important to the burner safety system and, if called out by NFPA 87, required by the best practices surrounding the heater."
27 Jan 2022
