OPC Problem
Please refer to attached file.
OPC Problem.docx
  • ASJ said:
    1. Symptoms 1)OPC data is not communicating or receiving with My Application Software. 2)My Application Software(customize software) operating normal with other applications, and no abnormal symptoms has been seen till now with any other software or system. 3)If we exit from and run the My Application Software again then we receive the OPC data’s properly. 4)We confirm that, in program, OPC data is lost when Error is identified in Event Log 5)Please check the below window event viewer captured error. 2. Window Event Viewer, Captured Event Logs 1) Application Error * English Translation in Detail Faulting Application Name: o_server.exe, Verson: 5.60.54.763, Timestamp: 0x52260a1e Faulting Module Name: MSVCR100.dll, 버전: 10.0.40219.325, Timestamp: 0x4df2be1e Exception Code: 0xc0000005 Fault Offset: 0x00001ed7 Faulting Process ID: 0x684 Faulting Application Start time: 0x01cfa2504b9e2c10 Faulting Application Path: D:\RBMnet\RBMSuite\Sys\o_server.exe Faulting Module Path: C:\Windows\system32\MSVCR100.dll Report ID: 2182c253-0f32-11e4-8bb1-d05099114ad8 2) Windows Error Reporting * English Translation in Detail Fault bucket , type 0 Event Name: APPCRASH Response: Not available Cab ID: 0 Problem signature: P1: o_server.exe P2: 5.60.54.763 P3: 52260a1e P4: MSVCR100.dll P5: 10.0.40219.325 P6: 4df2be1e P7: c0000005 P8: 00001ed7 P9: P10: Attached Files: C:\Users\CSISERVERS\AppData\Local\Temp\WEREFDA.tmp.appcompat.txt C:\Users\CSISERVERS\AppData\Local\Temp\WERF2D7.tmp.WERInternalMetadata.xml C:\Users\CSISERVERS\AppData\Local\Temp\WERF2D8.tmp.hdmp C:\Users\CSISERVERS\AppData\Local\Temp\WERFCA9.tmp.mdmp This file is available at. C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_o_server.exe_ceda1d4b76c61a568b1432d47305c951e206b45_cab_15affd13 Anaylsis Symbol: Rechecking for solution: 0 Report ID: 2182c253-0f32-11e4-8bb1-d05099114ad8 Report Status: 4 3) Csimtdbmgr * English Translation in Detail The description for Event ID 2 from source Csimtdbmgr cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event The following information was included with the event: thread(3048): [LC1209] Error - MTDBMgr.cpp (-5111) serverHandler() - Connection failed with Dserver-deokso; Value: -5111 network error code: 10054 4) Windows Error Reporting * English Translation in Detail Fault bucket , type 0 Event Name: APPCRASH Response: Not available Cab ID: 0 Problem signature: P1: o_server.exe P2: 5.60.54.763 P3: 52260a1e P4: MSVCR100.dll P5: 10.0.40219.325 P6: 4df2be1e P7: c0000005 P8: 00001ed7 P9: P10: Attached files: C:\Users\CSISERVERS\AppData\Local\Temp\WEREFDA.tmp.appcompat.txt C:\Users\CSISERVERS\AppData\Local\Temp\WERF2D7.tmp.WERInternalMetadata.xml C:\Users\CSISERVERS\AppData\Local\Temp\WERF2D8.tmp.hdmp C:\Users\CSISERVERS\AppData\Local\Temp\WERFCA9.tmp.mdmp These files may be available here. C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_o_server.exe_ceda1d4b76c61a568b1432d47305c951e206b45_cab_15affd13 Analysis symbol: Rechecking for solution: 0 Report ID: 2182c253-0f32-11e4-8bb1-d05099114ad8 Report Status: 0 5) “CsiO_Server” * English Translation in Detail The description for Event ID 2 from source CsiO_Server cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event The following information was included with the event: thread(4672): [LC0059] Informational - GuiThread.cpp (0) Logging thresholds: 'File' @ 'INFORM' 'Application Log' @ 'ERROR' 'Console' @ 'NONE' 3. Recent Status 1) Confirmed that, event log is visible before the communication is broken. 2) When we exit from program (My Application Software) and re-start, then My Application Software is receiving the OPC data, it means that OPC and My Application Software is communicating between them well. 3) This error occurs when the connection between the OPC is not broken, and seems to have the restored together, My Application Software attempts to forcibly reconnect but no response. To get response we must restart the program. 4) Window and program reinstalled, data request time is reconfigured (change the data requested time to longer) but the situation is same 5) Most of time it occur between 10 hours, but we confirmed that this occurs at approximate when it is more than 24 hours. 4. System Information 1) PC : I7 – 4770 CPU , 8GB Ram 2) OS : Windows 7 Professional 64Bit (Korea) 3) MHM version : 5.60 4) CSI 6500 Firmware Version : 3.20d 5) Application Program Tool : LabVIEW 2013
    OPC Problem.docx
  • Hello "ASJ",
    Welcome to Emerson Exchange 365. I provided a "cut and paste" a version of your transcript and copied in the DeltaV forum where you will receive a more subject-specific response. To continue your question/conversation, please join the DeltaV group by choosing the green plus sign in the upper right corner of that group's homepage. Because not everyone is able to read Word Documents, I recommend you cut and paste an abridged version of your transcript in the future.
    Also, I suggest you visit the DeltaV group and provide a brief introduction to your peers regarding your specific question or questions regarding this transcript. Please feel free to reach out to me if I can be of further assistance. Here is the link to the DeltaV group:
    community.emerson.com/.../3916.aspx
    Thanks!
    Best Regards,
