Login options after workstation configuration (Domain)
I have installed DV on a Proplus after settting up redundant IDDCs. I gave my domain credentials during the install when asked and the PP was joined to the domain. Good, I logged in with domain account. Good. Workstation Config finished. Now after that, next step is to log in and download the PP, Setup workstations, create config files and etc. However, my first attempt was to again login with domain administrator, but now I get a "time and date difference exists" error and it won't log me in. So, I log into the local machine with the Emerson account. That worked. However, the DeltaV services don't start. Hmm. okay. So, I see the DeltaVAdmin account listed under the login in Services. So, I don't know what the default password for DeltaVAdmin is. Couldn't find reference in a KBA. No problem, I go to my IDDC and change it in the active directory. Okay, good. So, now I log into the domain with DeltaVAdmin. Still DV services don't start. So, I try the domain admin login again. This time I don't get any time and date error. But DV services still doesn't start. So, basically I don't know what i'm doing.... LOL. I'm going to just login with DeltaVAdmin and manually start the service  and go on with life.. but I have a number of other workstations to setup and want this to go smoother.
Thanks
  • In reply to TreyB:
    That won't help you with regards to the service account. You will need to run the password utility mentioned previously on the machines which are built that do not have the password updated - the ProPlus in your case. When you add more machines you will be prompted to enter the new password during workstation configuration, so you won't need to manually run the utility on those.
    Whoops typo. It’s servpwd.exe
