DCS always prompt a alarm “Flow is above upper internal limit”.
Customer checked the AMS and found that the flow USL is lower than the URV!
Customer tried to use the EA software to change the flow configuration. For exmaple, the operation pressure or temperture,But the USL no change. It looks like nothing else can be changed in EA.
Could you advice a way to change the flow USL above 20000Nm3/h?
SammyWang 王敏辉
