Hi all,
I'm working with some OEM skid vendors for the purposes of integrating their skids into a Delta V installation. I will have a series of AB ControlLogix processors connected to my Delta V installation using EIOC modules. I have not worked with an EIOC module before, so I'm wondering how the configuration/mapping works between the systems. If I have the OEM vendors package the read/write tags that I need to interact with via the EIOC into a UDDT (User-defined Data Type) structure in RSLogix 5000, does the EIOC allow me to work directly with the UDDT? Are there limitations and configuration restrictions that I need to be aware of?
I have searched for the answer and through documentation but I have not been able to find the answer. I have purchased a development system to test out this functionality, but it is months away from arrival and I would like to know the answer sooner.
Hoping someone out there has done this work already...
Thanks.
EC
In reply to harshad.deshmukh:
In reply to Ekhchow:
One more thing on the topic of UDDTs - I understanding that it cannot take in a UDDT in its own format, but would it be possible to still map the supported data types (bools, dints, reals etc.) directly into the corresponding sub-datatype in the PLC? For example, if my "PLC_Comms" UDDT contains INT_WORD[3], and REAL_VAL[5], could I still map directly to PLC_Comms.REAL_VAL[0] for array length 5? That would let me still structure it into a UDDT structure on the PLC side (for uniformity's sake). Hope the question is clear. Thanks again. Ed
