Alarm Total in Alarm List
When the filter is used on Alarm list so that only certain priorities are shown, is there a way to have to total number at the top represent the total number of alarms remaining after filtering?
  • Kent, If you turn on the Status bar on the Alarm Summary ActiveX object it should show the correct number of items.
    Right Click on the Alarm Summary object and select Properties
    Then select the layout tab and check the status bar
    Then at the bottom you will see the counts. I have seen the counts that are using datalinks be "stale" and require the picture to be reopened to get the correct values but the status bar seems to always be correct.
