Remote I/O enable/disable error detection.
Dear Engineers,
one question for you.
On our plant we are working with Stahl remote I/Os with error detection active on each used channels.
Problem, when the process doesn't need some transmitters (PH transmitter), the operators unplug them.
The result is a OInteg = Bad on the controller.
Is it possible to enable or disable the error detection option on the unused input without downloading the node?
Thank you for your help.
  • Basically the answer is No, you will need to download. This is how the system communicate with each other on settings. Without downloading, it will not know to ignore it or watch out for error on the channel.
