Hello everyone,
I have a problem with DeltaV 12.3. I was configuring IO network for a client, based on a supplied IO list. I am using my own tool to translate client IO list into a bulk edit import files. After generating an import file for Foundation Fieldbus devices, all except 4 placeholders imported properly. In all 4 devices which generated errors, there were some spaces in the device names (like PT -262171) which I haven't spotted in the IO list. The devices generated an error message, but for some reason got imported into a system.
Problem: there are 4 devices called 'PT -262xxx' in the system, but not in the controller where they belong to. I can't see them in Explorer, only "Search" option finds them (there is a AI block with a defined name in each and Search finds this block). When I click "Select..." on the search window, it sends to be top level of Control Network. i would like to delete all 4 modules and create them properly.
How can I solve it? Automatated DB clean did not help. Any sugegstions?
Thank you in advance,
Marek
In reply to István Orbán:
