hydraulic actuator fail safe action as fail last
HI
we have a hydraulic actuator installed at our site which we want to modify to have the fail action position as fail last, for both power failure and hydraulic failure. I see there are two options for power failure case, option one is to keep the actuator full of hydraulic (two hydraulic operated pilot valves for open and close as normally open, meaning hydraulic keeps flowing to actuator during power failure) and the other option is to cut the hydraulic supply to the actuator during power failure, through the closing of pilot valves. My question is , is there an advantage of one option over an another and which one I have to go for ?
Thank you for your comments
  • John,
    Would you be able to provide more information on the actuator you have a question about? Brand/model/serial number would allow me to better answer your question.
    Thank you
  • In reply to Hakon Espvik:
    Hi Hakon
    Thank you for you message. Actuator is bettis G13-DA.
  • In reply to john :
    John,
    We would be able to better advise if we had a serial number to understand the controls on this actuator. Based on the information provided and assuming I understand you question correctly, option 2 in which you cut the hydraulic supply would be the preferred method.
    John,
