I have a DP flow transmitter with operating flow of 40-60 % of total calibrated range. if i re-range it so the operating flow reading is 80-90% of total calibrated range, in other words, lower the DP/flow range. Will this improve the accuracy of the transmitter reading ? is it true that the transmitters in general give incorrect reading at low values of the calibrated range?what is the percentage for the best accuracy? P.S. flow within flow element rangeability.
Thank you
In reply to Jeffrey Mach:
In reply to leirbag:
