Hi Everyone ,
I have a client who have recently switched to coriolis meters from Daniel for measuring the gas flow rate from a 2 phase vertical separator. They have mentioned the majority of the gas produced will be methane along with other impurities. However the separation efficiency of the separator can vary between 75 to 90%. Therefore , I was wondering the effect this can have on the over all performance of the flow measurement and what to expect, how will the volumeteric flow rate and density react to changes in wetness of the gas (liquid in gases).
we have currently supplied a CMF400H sensor coupled with a 2700 transmitter with 2 intrinsically safe outputs. I came across the option of two phase flow options (2 phase flow timeout , 2 phase low limit , 2 phase high limit) for density measurement in Pro Link III . It will be great if someone could explain, how to implement these parameters to tackle two phase scenario as best as possible.
Many thanks
Alan
In reply to Cara Wilmer:
In reply to Tom O'Banion:
In reply to alan thomas:
In reply to Jared Drennen:
