I often learn of developments within our organization from the global trade press. So is the case today when I read a tweet from Ireland’s @ReadoutSignpost (Eoin Ó Riain’s) tweet:
Industry-first measurement validation diagnostic on Rosemount temp transmitter #PAuto #Safety http://t.co/GvPN26j9
The link goes to Eoin’s Read-out Instrumentation Signpost blog, where he shares how the new measurement validation diagnostic in Rosemount 848T fieldbus temperature transmitters help to address some of the issues with thermocouple and RTD temperature measurement:
Temperature sensors, such as thermocouples and RTDs (resistance-temperature detector), can degrade over time due to harsh process conditions, vibration, and other factors.
I connected with Emerson’s Ryan Leino, a member of the Rosemount Temperature team, who shared some information on how the measurement validation diagnostic works. It provides validation of measurement data which can help identify the following issues:
These issues are often due to failing sensors (most common), electronic interference, corroded termination points, loose electrical connections, high vibration and runaway reactions. These conditions can lead to unnecessary shutdowns, inefficient energy usage, off-spec product, lower yields and unsafe process conditions. The measurement validation diagnostic can detect these measurement abnormalities and help plant staff take preventive action before they become a major issue, saving time and money associated with process shutdowns and helping processes run more efficiently.
As a temperature sensor starts to degrade, its signal noise will increase resulting in unreliable readings. Measurement Validation works by monitoring the signal noise and using it to calculate a deviation value indicating the magnitude of this noise. This calculated deviation value is then compared to a user selectable limit, which, if exceeded, can alert plant staff of an unreliable measurement point and possible sensor degradation.
Ryan and team have put together a measurement validation website that shares more on what the measurement validation diagnostic is and how it works, which includes several informational videos and a 3-D interactive product model.
MP3
The post Temperature Transmitter Measurement Validation Diagnostic appeared first on the Emerson Automation Experts blog.
