Hey folks,
I have been trying to use DeltaV InSight to tune a pH control loop, so far i have not had a lot of success due to slow response. Does anyone have a suggestion as to what is the best way to tune a slow response loop like pH?
In reply to James Beall:
I am using "On Demand Tuning".
In this particular case I am increasing the pH on a process stream before it reaches the next step. Below is the results from this mornings attempt at using "On Demand Tuning", it's the first time I have had some success with it. Usually the test times out.
In reply to Mark Coughran:
