I'm considering using an SFC to generate an output every time calculated injection period, through a serial card/link to open a pump solenoid in a Honeywell Enraf Fusion 4 additive injection system. The output, depending on the tonnage required, would be approximately every 5 secs to add the appropriate amount of additive. The SFC would be started by the operator who would enter the required tonnage and approximate loading rate to calculate the injection time period.
I'm wondering if this is actually possible?
We've been advised that using a DO charm is not desirable and that a relay baseplate would be required. These however have a lifespan of 1million outputs giving short operation due to the large number of outputs required each load.
Can anyone advise please or suggest another solution?
Thanks.
