I have a running system that uses a serial card to read and write data between DeltaV and ControlLogix. Initial configuration was set up on the Logix side to pass an array of 64 Integers and a Dataset of only 32 on the DeltaV side. My question is this if I increase the Dataset Properties / PLC / Number of Values from 32 to 64 and download the controller, will it disrupt the communications between the two systems?
Thank you,
In reply to Andre Dicaire:
