Newbie here...I opened up DeltaV Operate (Run). I selected the overview graphic and right clicked. I chose quick edit. I edited the color of a couple of rectangle objects saved and closed. I then hit running man to see my work.
No changes were there. I right clicked and went to quick edit. all my changes were there. I went to yellow pages and deleted the graphic I worked on from there. I then reopened operate (run) my changes were still not visible. right clicked to quick edit and all my changes are visible. closed and went to running man ... no changes..........
Is this the definition of insane?????
In reply to Matt Stoner:
In reply to Petrisky:
On your animation you will see an Advanced tab when the Data Conversion is Table. The other buttons will NOT be available meaning that it is connected to a Threshold (see example below)
When you click this you will an interface where you can see/define what Threshold is being used (see example below)
Threshold are located under the Globals object (see example below)
