Is placing PID block in "Bypass" bumpless?
I have a PID block configured to serve as a cascade "master" of sorts - I was attempting to manipulate a flow from a vendor skid. But they in turn have a flow loop configured (anyhow). The two loops are too close in dynamics, so I want to put our DeltaV PID block in "Bypass" (which I have enabled in control_opts).
The loop has been run in MAN for some weeks now . . . when I invoke "bypass" mode, will "manual" mode work as always (operator sets output independent of PV), and then when I switch to AUTO or CAS, the setpoint will be "translated" to 0-100% of the PV scale and applied to the output (right?). Will there be a "bump" in the output, and if so how might one ensure it is minimal?
John
  • Hey John,
    The BYPASS feature works very well. It will transistion bumplessly in the example you describe since a manual output will create the proper setpoint which will be tracked by a master loop via BKCAL_OUT of the bypassed loop. You might take a look at SP limits to make sure they won't cause a restriction as percent of scale. Be aware that the BYPASS feature even takes into account the controller action to keep the correct action of the master loop if the slave loop is bypassed. This might mean that a SP_HI_LIMIT is the low limit on the output! You might check this out.
    Hope this helps!
    James
