I always thought that a non-DeltaV computer should Not be connected to the Primary nor Secondary DeltaV Networks, I heard that in some instances (i.e. AV McAfee needs to have access to the Workstations), it is required and it is possible to connect a non-DeltaV computer to the DeltaV Pri/Sec network. I'm curious if that is possible, and if so, how do you assign an IP address to the no-DeltaV computer so that it can talk to other computers on the 10.4 or 10.8 network and ensure it is not going to impact with the rest of the IP addresses scheme, I know the ProPlus is who assigns IP addresses to nodes on the DeltaV network, but I don't think it can assign an IP address to a non-DeltaV computer.
In reply to Alexandre Peixoto:
