So I have installed an M-Series Serial Card series 2 in DeltaV 13.3 system. We have multiple configurations that use this similar setup so we are well versed in the configuration so that is what has me stumped.
Serial Card Configuration:
Port 1 Configured as
Enabled
Master
485 half duplex,
19200 8-N-1
all other settings default.
I do the full configure on port 1 and then download the I/O controller, the moment we do with no wiring we get a solid amber light (indicating a connection) on port 1.
If we do wire it as per BOL, terminals 2/4 , we are not able to communicate to the end device. No light changes
I put a different configuration (for a known working configuration) on the controller assign the serial port no amber light until connection to plc and it will communicate the same PLC.
I am stumped if I do the same configuration to Port 2 I get the same result of no communication/solid amber light
In reply to Dominick Rodriguez:
In reply to cpeavoy:
