I have a named state "TCU-58563" to be removed from a named set "_TCU_NAME_CHROM. I have removed all referenced recipe, unit parameters and equipment module action block expression. However, inside the named set, it still show the named state "TCU-58563" been referenced.
So I decided to set named state "TCU-58563" Visible = No and User Selectable = No. I perform a download of batch executive equipment and also the changed set-up data of all nodes in control network. However the named state "TCU-58563" reference remained as YES. Also since i have changed it to Visible = No and User Selectable = No, why the BOI still can have the "TCU-58563" selection provided?
Could anyone have a resolution for this? As the system is validated production system, where they require ALL changes to be done before a download can be performed.
Thanks.
I faced this issue, the option I was having is take the export of the named set, modify it in the text file and import it again.(the reference to the deleted named set value should not exist in database). That worked for me.
Karma doesn't have any menu, you get serve what you deserve.
In reply to Kartik29:
In reply to Jack_France:
In reply to Lay Lan Seah:
