Hello,
Based on My study on M-Series and S-Series analog input cards (4-20mA) i learn that it is all differential input kind of circuit.
if we compare to PLC then i have notice that PLC has Single Ended and Differential Input kind of wiring.
can you advise if my understanding above is correct ?
Also i learn that M-Series and S-Series Analog Input Cards use 24V DC from bussed power for powering the 2 wire transmitter loop ? is there any way we can use external power supply to loop power 2 wire transmitter connected to m-series and s-series analog input cards ?
Thanks for all your help.
Mitesh Maniar
In reply to Andre Dicaire:
In reply to Mitesh Maniar:
