Good Afternoon,
I had a quick question- I am trying to set up a development system. I have all the correct licenses loaded and assigned and can download the proplus successfully, but when i assign modules to the proplus to download (for simulation purposes), I get following error. I dont seem to get it for all module types, just anything with a PID or a DC Function Block in it, or a Unit Module, etc. Not sure what the reason is. I do know another system with similar licensing seems to be working fine. Any help or suggestions would be appreciated.
Regards.
In reply to imh301:
Hello, imh301. If you would like to add a photo to your post, follow these quick steps:
1. Under the post there is a blue button that reads More, choose EDIT
2. Put the curser where you want the image to land and Choose the Insert/Edit Media Button from the toolbar above the test field and you'll see this graphic, upload and choose insert
3 Click Insert
4. Hit Post
Best Regards,
In reply to Rachelle McWright:
In reply to SBPosey:
In reply to Andre Dicaire:
