What is ALM_HYS.
Anyone can help me what is ALM_HYS in ALM Block.Please provide an Example for better understanding Thanks.
  • I suppose you are talking about the ALARM_HYS parameter of the function block.
    This is the hysteresis on the alarm limit to have the alarm return to normal.
    Suppose you have an scale of 200, a high limit at 190 and an alarm hysteresis of 5%. Then the high alarm will be active when the IN value goes above 190 and will only return to normal when the IN value goes below 190 - (5% of 200) = 180.
    The ALARM _HYS is to prevent alarms toggling active/inactive when the IN value stays around the alarm limit (e.g. varies between 189.9 and 190.1 in above example).
