After importing configuration in a simulation system (v 12.3) the workstation was renamed using the DeltaV Workstation Configuration to have the P+ the same name as with the client.
Not sure whether this is the cause, but a download of the P+ seems to run perfect, until in the Progress log the Engineering Units are reported. Then an error: "An error occurred (error code 11, RT_INDEX_OUT_OF_RANGE" is reported.
The download ends, and the P+ remains 'No Configuration'.
What is the meaning of the error code 11, and how can I solve this problem?
In reply to Maarten van der Waal:
are you importing a older version program or just "copying" from an other system?
Have you checked the log files for any more information that could cause the problem "import.log and downlod.log..." ?
Have you checked the settings in your PC are the contry and time/date settings ok?
Niklas Flykt
Klinkmann Oy
nikfly@gmail.com
In reply to Niklas Flykt:
In reply to Brian Atkinson:
Best Regards,
In reply to Rachelle McWright:
