Protocol converter SNP GE Fanuc to ModBus RTU
Hi all,
I am looking for protocol converter from SNP GE Fanuc 90-30 ( info from schema - not sure whether it is right description ) to ModBus RTU ( DeltaV serial card ).
I have already found any gateway from Molex, but I have a problem with their technical support to confirm me this information.
I would like to ask you for help - have you used any similar converter / gateway in the past ( I assume any tested one )?
Thanks a lot for help.
Radek
  • Radomir,
    GE makes a module for the 9030 that allows it to talk Modbus TCP/IP, www.mynah.com/.../ge-9030-plc-modbus-tcpip-integration.  You could use this and the Schneider TSX Ethernet/Serial Modbus bridge or bring it in direct to the VIM.
    Please let me know if you have any questions.
    Mart
  • In reply to Mart Berutti:
    Mart,
    Thanks a lot. I was thinking about checking your website for solution, but at the end I decided to leave it ( no results in google in the front - the same for GE, but maybe it is only because of playing with searching:-) ). It seems there will be always better to check your solution first:-).
  • In reply to Radomir Pistek:
    I wanted to pass along this tweet from Bart Schaminee:
    @EmersonExchange you can try Horner or use a small RX3i of GE Fanuc as gateway.
  • In reply to Jim Cahill:
    I would like to summarize possibilities for integration only:
    Modbus TCP/IP  9030 GE Fanuc module
    Modbus RTU - IC693CMM311 GE Fanuc module ( slave )
    Modbus RTU - HE693RTM705 Horner APG ( master )
    Above solution is necessary compare regarding CPU version and so on - see datasheets, module is fixed on GE Fanul carrier ( necessary to have spare slot on FIRST carrier )
    3rd party solution:
    RX3i
    APP-ESR-GTW
    above are "gateways" - possibility to connect "several" links and should be fully programmable.
