Is there some way to get the "Profibus Device Information" you can find in "diagnose" out of DeltaV. (see image)
Purpose is to log the errors and details of the errors to an external logging system (OSI PI).
There is some information available through OPC, but not the general information of the profibus device.
Deltav v11.3 offers a new diagnostic call for Profibus Devices. The diagnostic parameter is returned a a byte array in a control module and the data can then be exposed usning a CALC block expression. A sample module is provided that exposes diagnostic data from a Siemens SIMOCODE device.
The parameter is created as and external reference, call it DEVDIAGDATA. The path of this reference uses the device name defined in DeltaV with the following syntax: /&MY_DP_DEVICE/DIAGMSG.
The CALC block expression is then able to read the various bytes in the array and extract bit status or combine bytes in to integers, based on the significance of the bytes. The SIMOCODE example provides the following parameters from the diagnostic data, and these are provided "free" (no DST cost)
OVERLOAD_WARNING
THERMISTOR_WARN
OVERLOAD_FAULT
THERMISTOR_FAULT
CHECKBACK_FAULT
MOTOR_STALLED
NUM_OVRLOAD_TRIP
TRIPPING CURRENT
OPERATING TIME.
The mapping and number of bytes will vary by device so one needs to know what the data means in order to map it to appropriate parameters. I would create a composite block for each device to read and extract this data so that the modules remain clean and data is presented consistently.
On my system, the DIAG MSG from the Diagnostic screen for a Unidrive VFD shows the following:
Diag Msg
Station Status 1: 0x08
Station Status 2: 0x0c
Station Status 3: 0x00
Device Master Address: 0x01
High Byte Of Identifier: 0x0b
Low Byte Of Identifier: 0x4f
Extended Diagnostic Data:
Byte 001 - 010: 0x0c 0x81 0x00 0x00 0x00 0x04 0x00 0x00 0xca 0x93
Byte 011 - 012: 0x01 0x41
The status 1, 2 and 3 Bytes above are returned in bytes 1, 2 and three of the DIAGMSG call. The Device master address and the high/low bytes of Identifier match bytes 4, 5 and 6. The extended Diagnostic data begins at byte 7. I don't know the mapping of the extended diagnostics, and this would be specific to the device.
Maybe teh Status bytes map to the individual bits in the information form you are asking about. There are 16 bits exposed in the form which would map to status 1 and 2, and status 3 may describe the Device Status? However, I don't know which bit is in which position in the bytes.
Hope this helps. Maybe someone can help us out with the rest of the data mapping?
In reply to Andre Dicaire:
Thanx for this complete and clear answer.
As we're still on V10.3 we will need to upgrade to get this info.
Then a littlebit of bit and byte ordering en searching, and we will get there.
Kind regards
Jeroen
In reply to Jeroen Hoorelbeke:
Hi Jeroen, I've also checked with some of our fieldbus consultants in Austin and asked if they had additional points to add to Andre's note.
Jeroen;
Andre has done an excellent job of describing the Intelligent Diagnostic Data that became available in DeltaV 11.3, however I'd like to add a few items that may be helpful.
The information that is available on the General Properties Context Menu is part of the Standard Diagnostics which per Andre's response is the first 6 bytes of information returned for the device as Extended Diagnostic Data. Extended Diagnostic Data can have as much as another 238 bytes of optional diagnostic data for a total maximum of 244 bytes. This mandatory data or Standard Diagnostic Data should be available for all devices and maps as:
Byte 1:
Bit 0: Station not existent
Bit 1: Station not Ready
Bit 2: Configuration Fault
Bit 3: Slave has Extended Diagnostic Data
Bit 4: Slave does not Support the last requested Parameter Function
Bit 5: Invalid Response
Bit 6: Slave did not Accept the last Parameter Data sent
Bit 7: The Slave is controlled by another Master
Byte 2:
Bit 0: Slave Requires Parameterization
Bit 1: Master is Requesting Diagnostics
Bit 2: Bit is always "1"
Bit 3: Watchdog is On
Bit 4: Slave Freeze Mode is On
Bit 5: Slave Sync Mode is On
Bit 6: Reserved
Bit 7: Slave is not enabled
Byte 3:
Bit 7: Diagnostic Overflow
The rest of the bits for Byte 3 are reserved.
Byte 4:
Master Station Address with address 255 reserved for a slave device with no Master
Byte 5:
The Most signification byte of the Profibus ID of the slave
Byte 6:
The least signification byte of the Profibus ID of the slave
These Bytes are always available from the device using the method described by Andre making sure that you expose these directly from a reference parameter or a Calc block. A possible Calc Block Expression to read these might be:
I F ( ' ^ / D E V D I A G D A T A . C S T ' = 0 A N D ' ^ / D E V D I A G D A T A . S T ' = 1 2 8 ) T H E N
( * G E T T H E V A L U E S O F E A C H B Y T E I F T H E C O M M U N I C A T I O N S T A T U S I S N O R M A L
A N D S T A T U S I S G O O D * )
' O U T 1 . C V ' : = ' ^ / D E V D I A G D A T A [ 0 ] . C V ' ;
' O U T 2 . C V ' : = ' ^ / D E V D I A G D A T A [ 1 ] . C V ' ;
' O U T 3 . C V ' : = ' ^ / D E V D I A G D A T A [ 2 ] . C V ' ;
' O U T 4 . C V ' : = ' ^ / D E V D I A G D A T A [ 3 ] . C V ' ;
' O U T 5 . C V ' : = ' ^ / D E V D I A G D A T A [ 4 ] . C V ' ;
' O U T 6 . C V ' : = ' ^ / D E V D I A G D A T A [ 5 ] . C V ' ;
' O U T 7 . C V ' : = ' ^ / D E V D I A G D A T A [ 6 ] . C V ' ;
' O U T 8 . C V ' : = ' ^ / D E V D I A G D A T A [ 7 ] . C V ' ;
One must use a parameter, say in this case, "DEVDIAGDATA", which is an external reference to /&MY_DP_DEVICE/DIAGMSG. This is necessary since diagnostic data is not directly allowed to be accessed. Also as a reminder, this data is being returned as a new data type for DeltaV, BYTE ARRAY. It functions somewhat like a FLOATING POINT ARRAY, but as the name states the values are handled as bytes. Another difference is this data is being returned by the controller as a dynamic byte array since the return of the data is dependant on the diagnostic returned and the way that the device was designed. This can differ somewhat between devices even if they are the same type of device, I/O, VFD, Flow, Motor Control, etc, although there is some structure to it. If you're interested in a further understanding of this optional data and the structure, I'd suggest checking out the Profibus Specifications.
One point on your question was the pulling of this data through OPC Mirror. Since this is diagnostic data, it will not be directly available to you, however you can pull this through using a module. The positive side of that is that you can then organize the actual bits that you wish to use for each type of slave device on the Profibus segments.
I hope this can assist with getting you started on the mapping and organizing of the bytes/bits once you get upgraded.
Adding following summary as i understood. Might be useful for someone new who comes to this thread
