Hello everyone,
I have Problems with connecting a gateway netTAP NT 100 from Hilscher into DeltaV. The communication will be established through EtherNet/IP. Communication is configured, and working properly (I see the good status in Diagnostics). But if I configure the exchangable data, it shows me Bad status and not comunicating anymore.
Does anyone has experience with gateways netTAP NT 100 from Hilscher? Can anyone help me with configuration of TCP IP?
We have tryed different options but the device doesnt want to communicate. The data set is set up as per gateway settings with matching on both sides.
In reply to Matt Forbis:
Hi Matt,
I have a Wireshark File. It can probably help you to analyse what is going on in network. WiresharkDaten.zip
In reply to KoBriZo:
I am forwarding actual configuration screenshots to you which is matching to Wireshark Data. We desided to start with small ammount of data in order to analyze how it works.
