I have a CFT51 coriolis flowmeter which only has Modbus and I can connect to the unit but as soon as I add a dataset, communications go bad. The flowmeter Modbus map uses registers as an example, of
303001 where three indicates it's read only, zero is called a separator, and 3001 is the actual value which I want to read. The problem may be in the number of digits. When I try this in a dataset, the register shows up as R33001, six digits. When I add the dataset, it goes bad in Diagnostics. Has anyone experienced this on a like or similar instrument or device?
