Remote workforces, social distancing, reduced labor efficiency — these are just a few of the buzzwords surrounding the “new normal” manufacturers have faced since the global pandemic. Unfortunately, these are also challenges that are layered on top of existing production pressures. For many operators, the onslaught of concerns surrounding new technologies, climate change, labor shortages and operational efficiency is causing an examination of their day-to-day operations. In this intersection of challenges and pressures, the Industrial Internet of Things (IIoT) — and the digital transformation it enables — is poised to unleash an era of manufacturing that is more reliable, more efficient and more sustainable than ever before.
Despite the maturity of the technology found in many manufacturing facilities, competitive pressures have increased in some new and very specific ways. Understanding these operational and profitability challenges is the first step to facing them — and in preparing for long-term sustainability.
When properly leveraged, the Industrial Internet of Things (IIoT) can help manufacturers connect islands of automation, unlock trapped machine data and empower workers to deliver greater value. In a typical manufacturing facility, there may be dozens of machines that are involved in producing a finished product — and an inefficiency in one can create a cascading effect across the entire plant. By connecting individual machine “islands,” and the data they individually provide, an operator can determine if one machine is running more efficiently than another and can spot potential issues before they become bigger problems. But connecting these islands of information isn’t just about data collection — it’s about extracting the most valuable insights and then piecing them together in ways that help operators make informed decisions. And it’s also about starting with a scope that is both reasonable and understandable.
The AVENTICS Series AF2 flow sensor.
For example, in a manufacturing plant that relies on pneumatic operations, the benefits of IIoT are realized most effectively by monitoring air usage within systems — something that can easily be accomplished on just a few machines. Using sensors like the AVENTICS Series AF2 to measure airflow, the system can identify the machine exhibiting the problem and send alerts directly to maintenance staff. By starting at this more individualized, machine level, operators can obtain actionable insights without the need for heavy data analysis — and very quickly realize a reduction in costs, improved production quality, increased throughput and, in the case of pneumatic systems, improved sustainability.
Information obtained through IIoT can disrupt the status quo and enable manufacturers to create future-ready operations — with a quantifiable return on investment (ROI) they should start seeing in under 12 months. The key is to partner with the right device manufacturer to support the digital transformation and implement the appropriate solution.
Emerson’s PACSystems RXi2-BPEdge computing device.
Flexibility: Together with scalability, device flexibility is critical. This is most easily realized by choosing devices that rely on open communication systems and architectures. The industry is evolving quickly and being locked into a proprietary solution can prevent an operator from taking advantage of the latest technologies. In the fluid power and motion control sector, there is not yet a single, industry-wide set of IIoT standards, which is why it’s critical for any solution to be as open and flexible as possible.
Monitoring airflow over time can help detect leakage and alert staff of excessive air usage, enabling proactive maintenance and greater operational efficiency.
As we face the simultaneous demands of a changing world and ongoing competitive pressures, by rethinking old paradigms and leveraging the power of IIoT, operations can move forward with greater confidence and a renewed ability to meet both present and long-term needs.
Previously published in Fluid Power Journal
The post Achieving Future-Ready Operations Through Digital Transformation appeared first on the Emerson Automation Experts blog.
