Search
Search
Services
Products
Control & Safety Systems
IIoT & Digital Transformation
Industries
Chemical
Food and Beverage
Industrial Energy
Life Sciences
Oil & Gas
Power
Refining
Other Industries
Women in STEM
Events
Nashville 2019
San Antonio 2018
The Hague 2018
China
Russia
Products
DeltaV Blog
Flow Control – Positive Displacement Pump Part 2
Forums
Blogs
Library/Resources
Members
Tags
Terry Blevins
17 Mar 2014
pump
Control
"backpressure regulator"
Education
Process Control
relief
Control Design & Commissioning
Flow
valve
"positive displacement pump"
Final Control Elements
Options
When using a positive displacement pump in flow control, then the minimum flow which may be achieved using a variable speed drive is limited by the motor low speed limit. It is possible to achieve a wider range of flow control by regulating flow using a fixed speed motor and a throttling valve in combination … Continue reading »
Read the full text.
