Search
Search
Services
Products
Control & Safety Systems
IIoT & Digital Transformation
Industries
Chemical
Food and Beverage
Industrial Energy
Life Sciences
Oil & Gas
Power
Refining
Other Industries
Women in STEM
Events
Nashville 2019
San Antonio 2018
The Hague 2018
China
Russia
Products
DeltaV Blog
Flow Control – Centrifugal Pump
Forums
Blogs
Library/Resources
Members
Tags
Terry Blevins
3 Mar 2014
pump
centrigugal
Control
Education
motor
Control Design & Commissioning
Flow
valve
throttling
Final Control Elements
Options
Centrifugal pumps can be used to transfer large volumes of liquid between vessels in an industrial process. When a constant speed motor is used to drive the pump then the pump flow rate may be controlled by adjusting a throttling valve that is installed after the pump discharge, as illustrated below. The pump discharge pressure … Continue reading »
Read the full text.
