Search
Search
Services
Products
Control & Safety Systems
IIoT & Digital Transformation
Industries
Chemical
Food and Beverage
Industrial Energy
Life Sciences
Oil & Gas
Power
Refining
Other Industries
Women in STEM
Events
Nashville 2019
San Antonio 2018
The Hague 2018
China
Russia
Products
DeltaV Blog
Deadband and Resolution Limit Cycle Causes and Fixes
Forums
Blogs
Library/Resources
Members
Tags
Gregory K McMillan
9 Aug 2012
Shaft-windup
Limit Cycles
#apw10
resolution
backlash
deadband
Hysteresis
stick-slip
Options
Deadband and resolution cause sustained equal amplitude oscillations called limit cycles that cannot be eliminated by controller tuning. A resolution limit causes limit cycles if there is integrating action at just one point in the control loop either in the process (e.g. level), positioner, or the process controller (e.g. PID). Deadband requires integrating action at 2 or more points in the control loop. The best solution is to eliminate the source of the problem but there are fixes.
read more
