Variable speed pumps can save energy when the flow is reduced. However, the turndown of the pump speed may not achievable if there is overheating at low flows, excessive sensitivity at low rpm, and cycling at high destination pressures. Special attention to variable frequency drive (VFD), motor, pump, and piping system design is necessary to achieve the rangeability associated with the energy savings.
read more
