Is there an easy way to print ALL parameters of an FF instrument from AMS? The print function basically only prints the active page.
I know there is a possibility to export to XML, but it is just more work to get it formatted into a nice report.
I saw several calls on SMS regarding this, but I did not find the solution.
Istvan
Istvan,
The best option is to export (I would recommend opening within Excel), however there is limited functionality based on what the functionality within the DD for printing. If you right-click on a device and select "Process Variables" or "Configure" then click the print button in the top left corner it will allow the variables to be printed. Make sure you have selected "Manual Setup" as that will show the variables, where "Guided Setup" will not.
Hopefully this helps and answers your question, if you have further clarifications please let me know.
Steve Tooley
