Rigging is a very important part of almost all industries, such as Manufacturing , Construction, Oil and Gas , Marine and Forestry. In fact wherever and whenever there is a need to carry heavy loads from one place to another, rigging is used. Proper rigging hardware allows a site to operate with more efficiency. It is therefore important for all workers to be familiar with the different aspects that ensure an efficient rigging operation that meets the highest standards of safety.The fact that they are used to carry heavy loads, makes it necessary to ensure safety while using them. The safe and correct use of rigging equipment will lead to the safe and easy handling of loads. On the other hand, if you do not consider the various safety tips that deal with the proper use of rigging, you might suffer from an on site mishap resulting from an imbalanced crane or a load that comes crashing down from the rigging.Following are the key aspects that affect any rigging operation:Selecting The Proper EquipmentSelection of appropriate lifting equipment for the job is essential. Ensure that the machine or equipment selected for the job has sufficient capacity and can bear the weight of the load. In case of crane, crawler or a tower, the lifting capacity depends on the load capacity of the crane boom, hence it is important to calculate the distance between the load and the crane.Special attention should be given to the load-bearing parts, such as, wire ropes, slings, braking mechanism, equipment safety, etc.
Considering The Type Of The LoadIt is important to know the material of the load. Only then is it possible to know the appropriate sling to be attached to it.
Lifting CrewHuman error is one of the most known causes of failure in rigging operations. It is important that every member of the lifting crew is well trained and qualified for the job.
Rigging MethodsAlong with aspects such as machines, crew, material, it is very important to be aware about rigging methodology. It is important to consider factors such as weight of the load as well the load capacity of the equipment used. Following are the important points to be kept in mind before lifting or moving the load.
End WordsIt is critical to note that none of the lifting hardware should be overloaded under any circumstances. It is always important to choose the right rigging hardware in order to ensure fall protection and safe rigging operations. Keeping the above mentioned facts in mind will help you plan a safe rigging operation.
