Many plants have process units where multipoint temperature sensor arrays are used to capture temperature profiles to detect hot-spots, or where multiple single temperature points are within close proximity. Multi-input temperature transmitters are ideal for applications where there are many temperature measurements clustered together. Applications include:
To condition these sensor signals in the past you used to have to decide between accuracy, using many single-point measurement transmitters, or low-cost using control system temperature input cards or temperature multiplexers. However, multi-input temperature transmitters provide both the precision of field mounted transmitters, and economy using wireless or using only a single pair of wires from the multi-input temperature to the junction box and is two-wire loop powered Thus, no separate electrical power is required. The solution can be intrinsically safe, non-incendive, and flame/explosion-proof, making it suitable for all hazardous areas. All sensor signals are carried on the same two wires or over the air.
Some reactors and heat exchangers around plants may not be continuously monitored, relying on manual data collection because they were never instrumented due to the high cost of temperature input cards and compensation wires, or single point transmitters, wiring, and analog input cards. Modern plants are now built with multi-input temperature transmitters at lower cost, and existing plants can be modernized with multi-input temperature transmitters where measurements are missing.
Around-the-clock automatic device diagnostics monitoring alerts personnel to problems like sensor failures.
The right temperature is important for the operation of many processes. The wrong temperature will impact plant throughput, quality, and yield. Temperature is also important for maintenance, as high temperature is a leading indicator of problems in motors and machinery. If left unattended, improper temperatures can result in plant downtime and maintenance costs. Deploying transmitters to cover these missing measurements therefore makes sense.
A single gateway can be used to integrate hundreds of temperature points into an existing control system.
Read about one such modernization case here:
http://www2.emersonprocess.com/siteadmincenter/PM%20Central%20Web%20Documents/QBRExxonMobil3feb.pdf
What other applications are there where there are multiple temperature points in close proximity of each other such that it would make sense to use temperature transmitters with 4 or 8 inputs?
