Deltav Excel Addin in Deltav 15
I need top use Excel addin in deltav 15.
1- I have licence.
2- I have a Excel snapshot file for a deltav module.
I have upgrade deltav to version 15 and i can't find ExcelAddIn install.
Do you know where is it ?
I hope Emerson hasn't abandoned this solution.
  • I assume you are referring to the bulk edit add-in? If so it is located in "D:\DeltaV\DVData\BulkEdit" folder in v14, and I expect it is in the same folder location in v15.
  • Hello.
    You can find information on books on line.
    Introduction to the DeltaV Excel Add-in
    Install the DeltaV Excel Add-in
    The DeltaV Excel Add-in can only be installed by the local administrator or by a user in a group with administrator privileges. Prior to installation, you must start Microsoft Excel at least once to create Registry keys required by the DeltaV Excel Add-in.
    Important:
    Any additional user who wants to use the DeltaV Excel Add-in on the workstation where it has been installed must also complete the steps in Set up users below. These steps are also required for a user account on a Remote Desktop Services system, including the user who installed the DeltaV Excel Add-in.
    To install the DeltaV Excel Add-in, complete the following steps:
    Log on as a user with administrator privileges.
    Start and exit Microsoft Excel.
    In Windows Explorer, navigate to \DeltaV\bin\ExcelAddInRuntime, and then double-click setup.exe.
    If the Excel AddIn Runtime dialog appears, prompting you to install additional required items, click the Install button.
    If a prompt appears, indicating that the installation of the DeltaV Excel Add-in needs to restart the computer, click the Yes button.
    When the Customer Information dialog appears, enter the name of your organization in the Company Name field, select the Anyone who uses this computer (all users) option, and then click the Next button.
    When the Ready to Install the Program dialog appears, click the Install button.
    Following installation, you can select DeltaV Excel Add-in options by navigating to DeltaV → Runtime Data on the Add-Ins ribbon of Microsoft Excel.
    Set up users
    Related information
    Uninstall the DeltaV Excel Add-in
    When Deltav Excel Add-in has been installed follow the instructions on "Set up users"
    I hope, it help you.
  • In reply to fraguila:
    Thanks ,
    But The folder "\DeltaV\bin\ExcelAddInRuntime" doesn't exist.
  • In reply to laurent maurer:
    Sorry I found the folder and i activate ExcelAddIn on my PPLUS.
    Thanks
    That addin only allows runtime data. On DV14 I was able to access historian as well. Do you know how I would go about adding that too?
  • The Excel Add-In is for runtime data. To get historical data from the DeltaV Continuous Historian you should install DeltaV Reporter following the instructions in the "Install DeltaV Reporter" topic in Books Online. (DeltaV Reporter installer is on the DeltaV media under \DV_Extras.)
