Hello Madames, Sirs!
I kindly ask you for a solution for the following task:
I am having a Counter value that has to be stored permanently. Therefore I am using a CALC block variable.
As long as I do not decomissioning the Controller, it works perfect. So, I can down the Module and open the module and the parameter value is as it was before the download.
But if the Controller has been decomissioned, after (re)commissioning, the counter value (CALC block variable is set again to its initial value.
Q: Is there any possibility to restore the actual value of the counter?
f.ex: Counter value before decomissioning = 3
Counter value after recomissioning = 3
So far, i am getting always the initial value, f.ex. 0.
Would be nice to get some ideas, BR Horst
In reply to Andre Dicaire:
Hello Andre!
I am going ahead wiht your proposal to find out how it works with the SYSSTAT parameter and with the backup and source modul.
Thank you for this great solution !!!
Have a nice day,
Horst
(So by the way, I am new in working with DeltaV, but I already like it :-))
