I am stuck on run a bat file, which I thought is very easy because I was taught how to run notepad.exe in Emerson 7425 training.
I successfully started notepad by follow steps:
1. create a private string standard, name "notepad", with value of
"c:\WINDOWS\NOTEPAD.EXE;NoSignatureCheck"
2. for test purpose, use F5 key in layout and its script:
if(key=="F5")
{ENV.RunAsync(GL.Library.notepad, "")}
it failed when I change the value of standard to "c:\test\copy.bat;NoSignatureCheck" , which shall copy 1.txt to 2.txt.
please help!
