I am looking for a way to figure out in bulk a way to see which modules were converted to class less or were created never using a class? is this possible? is there way to list which classes are being used per module?
I am trying to avoid right clicking 5000 CM's
thanks for any help
In reply to István Orbán:
The only way you will be able to tell about if it was created by class or not is by looking at SUB_TYPE or TYPE and hopefully they will be different. Typically if a module was created from scratch these would be "". The below are the bulk edit fields you would need to pull to check these and compare to the classes.
As far as the other item about what classes are used, you can use PowerBI Desktop (free download) to get this information pretty easily. Here is a view of this I ran on an demo FHX I had.
Here is a view of the Visualization settings for this "Stacked Column chart" (You can get this data once PowerBI is installed within 5 mins or less!)
You could probably also use PowerBI to help determine the Class/Classless from above using the FHX easily as well.
Matt
In reply to Matt Stoner:
In reply to tommy430:
Yeah I converted to XML first most likely (forgot about that), I used the FhxToXml2005.exe which you can type from command prompt:
