UNABLE TO OPEN DeltaV EXPLORER
After a power failure, we have been unable to open the DeltaV Explorer and all other engineering applications on the Pro+ station.
The following error message pops up "FAILED TO OPEN DATABASE".
The system event log contains the following error code "15530".
I will appreciate if anyone can assist with likely solution to the problem.
Thank you
  • If your ProPlus shut down unexpectedly, you may have locked the Database. Easiest solution is to create a new one from an existing backup or from a .FHX file. Make sure the Database is registered and then make this newly created DB "Current".
