Hello Ladies and Gents,
I have read that the DeltaV network is designed to use a star topology. Is it correct to say that all primary switches should be connected to a single switch, preferably to the switch where the primary connection of the controllers are connected to? same goes for the secondary network? Another question is about the uplink port of the switches, does this function as a trunk or does it function just like an ordinary uplink port of a hub? Would it drastically affect the ACN if you daisy chain all the primary switches together via the uplink port? (same scenario for the secondary network)
Thanks in advance!
Dominic
