Research engineer Daniel Eilers is responsible for noise and vibration testing, noise prediction development, and computational fluid dynamic simulations of flow-through control valves. He recently wrote an article for Valve Magazine highlighting findings from an oil refinery. For the full version of the article, click HERE.
PINPOINTING THE SOURCESince the exact noise source could not be identified using acoustic sound pressure level measurement techniques, which was the process used earlier by the consulting firm, the efforts to measure vibrations began with a survey of the quench valve area to determine where to begin testing.
Accelerometers were used to allow testers to isolate a specific component for analysis, which leads to a systematic evaluation and subsequent elimination of suspect piping and valves.
To determine whether the noise source in this case was upstream of the valves with noise then propagating through the system, the accelerometers were mounted upstream and downstream of the motor-operated valves that feed the quench valves. Following measurements taken at these locations, the sensors then were placed immediately upstream and downstream of each quench valve, as well as mounted on the stem of each valve.
The highest piping vibration levels were found next to the quench valves, with the highest overall reading being taken on the valve stems. This finding indicated that the source or cause of the noise was most likely the valve trim components.
Stroking the quench valves was shown to impact the tone of the noise. Depending upon the travel, the tones would disappear, increase or change frequency.
The quench valves were 25-year-old units that used post guiding of the valve plug. In such valves, if the tolerance between the plug and valve body is too large, the plug/stem assembly can vibrate. If the assembly is excited at the resonance of the plug/stem component, the vibrations can cause tones.
Do you have a noise question for our experts?
Whether it's noise, cavitation or any critical/ severe applications, Fisher valve solutions is it. We are the best! We hold more patents more than anyone else.
Seriously speaking, our reliable performance is well known in the industry. It's a time proven, undisputable fact :-). Check out our sites: www2.emersonprocess.com/.../FisherSevereService.aspx
Sample brochure preview: www.documentation.emersonprocess.com/.../d351989x012.pdf
In reply to Ng Winsom:
More noise information is available in this noise video.
www.youtube.com/watch
In reply to Kyley Leger:
I thought this was a great story of tracking down the noise issue and solving it with some cage-style noise abatement trim in the quench valves. Here's a recap of the story in an Emerson Process Experts blog post.
In reply to Jim Cahill:
Hello Everyone,
I came across a high noise problem in several control valves installed in my refinery. This high noise from valves was first reported just after commissioning of the plant; however, at that time it was suggested that the noise was due to the line hydraulics and vibration of pumps and compressors. But now after 3 years, the area operators insist that the noise is being generated from the valves as conventional tests have shown about 96 dB 1 meter downstream of the valve, 1 meter away from the line.
My question is that, is there any way or standard to confirm (in line) that whether this 96 dB is being generated from the valve or is being added from surroundings. How can I measure the exact noise generated by the valves, in line?
Inline noise measurement methods in light of international standards are more appreciated.
Best Regards.
In reply to MAnasJawed:
The Valve Magazine article may be helpful, please follow this link: www.documentation.emersonprocess.com/.../vlv_mag_noise_source.pdf
Thanks Kyley Leger, it was helpful.
