We know that when creating temporary IP addresses in the previous version of IC695ETM001, it was possible to create them through MAC write, but this feature was canceled after the new version of 10.0. Although the new version of ETM001 comes with a temporary IP address when it leaves the factory, there are more older versions of ETM001 in use on site, and the cancellation of this MAC write greatly reduces the customer's use experience.
Is it possible to restore or add a patch?
I don't think there is a necessary connection between using the new version of ME10.0 and ETM001 on site!
In reply to Steve Ward:
In reply to Jack.Zhang:
Hi Jack, I ended up creating a .bat file that will do the same function as the utility. Fill in your interface/adapter name, IP address and MAC. You have to enable telnet and run the bat file as a local administrator for this to work. Of course you can also type the three bottom lines into a command prompt window (as local admin). Just replace the parameters.
REM bat file to set temp IPREM on Win 10 enable Telnet firstREM run this "as administrator"
SET interface="Ethernet1"SET ip="192.168.0.100"SET mac="00-09-91-01-23-31"
REM delete arp cache / set arp entry / telnet to interface to set IPnetsh interface ip delete arpcachenetsh interface ip add neighbors %interface% %ip% %mac%telnet %ip% 1
In reply to Mats Andersson:
