As I know, Ovation points can be forced one after one and similarly clear the force one by one in signal diagram in Ovation software. My question is, how and where to clear the forced points at one time in signal diagram window in run time instead of one by one. Is there any procedure or settings to clear the forced points in current signal diagram?
Filter All the points with "Scan OFF" in the "Point Review". Select all the Points needed to clear force.
Make "Scan ON" to remove the force.
