Hello,
We have temperature reading for a freezer at our factory. This signal is recorded and stored in the historian server.
Our system is Delta V 11.3.1 build 4326.
Maintenance keeps a printed trend (paper record) for every month by our procedures.
There was a human mistake changing the title dates and other department requested to re-print July 2018 readings.
However, when we pulled out this temperature chart, the data that is in the printed paper does not match with what we are able to get from PHV today.
The events for this signal match what we have in PHV, there was a point in time where a download in the controller was performed and the temperature status changed to bad, this behaivor generated a spike in the trend that I think is normal while the CM is initialized after a download. At this point in time the events and alarms generated match the PHV signal.
I went back in time to verify the printed trends in paper and compare them with PHV values today, there is no descrepancy whatsoever. The only time where is different is for July 2018.
In reply to Andre Dicaire:
In reply to gennarogiura:
