Threshold Enable Question
I am enabling some thresholds inside the control module (LO_LO, HI_HI, etc)
In version 12.3.1, I am seeing:
THRESHOLDS$TH$ENABLE (Groupname IO) and THRESHOLDS$TH_ENABLE (Groupname Tuning)
What is the difference?
  • That is an error in the Class allowing configuration of THRESHOLDS$TH$ENABLE as that parameter will be overwritten by the wire from THRESHOLDS/TH_ENABLE parameter.
    You only need to configure THRESHOLDS$TH_ENABLE and should ignore/remove the THRESHOLDS$TH$ENABLE configuration.
