I have a device whose assembly object class does not include the information I desire. From what I can gather, when adding devicenet signals in Explorer, it uses the assembly object based on the EDS file and signal direction specified. However, I would love to be able to add signals/ device tags here for other object class items.
I found that there was supposed to be explicit messaging via external references to particular parameters, however this did not work for me. I can give details, but at this point I'm looking for a more general or better solution. I decided to try accessing the device diagnostic data that was already being made available through Diagnostics.. at least then I had proof of data. However, this data did not come across in the module either. I confirmed the class ID, instance and attribute IDs with the device's programming manual. I have confidence I'm not at fault there.
Any suggestions?
Thanks
In reply to Tinh Phan:
In reply to TreyB:
