Hello All :
I want to discuss the issue can same user name of Administrator have 2 different passwords as i have seen then what does it mean
example administrator pwd is 123
Administrator pwd is 123123
normally username administrator pwd is 123 is used username administrator pwd 123123 is used once when re run the configuration of actual fhx...(at that time it was not accepting the pwd 123)
now username administrator pwd is 123 is also used in operator stations only when change required in limit and then back to op user name and pwd and yet engineering station also use user name : administrator pwd is 123
i want to change the pwd 123 of administrator as operators came to know the pwd...at Hlp document is quite confusing .....
user manager and servpwd.exe
if i used user manager for username administrator pwd is 123 to change the pwd what steps shall i follow so that operator station username administrator pwd is also changed
if find any difficulty to understand just tell me how to change the password in engineering station and then what to do in operator station for Administrator in steps
In reply to Alexandre Peixoto:
In reply to Sami Uddin :
User manager is not accessible in operator stations... Shud I use the change pwd.??
