When I want to know what parameters use each other in the different module I use reference from toolbar but there are too many parameters that their references are not clear .another things about the blocks that use expression .references from experssion in the whole module are not exactly clear.this the very complicated for troubleshooting. Please guide me if there are clear way to trace parameters to drill between modules
Update from Emerson Community Site Bruce Brandt Notice the column that says "uses" or " used by" . Sort on that column since most of what you're looking for is usually a used by parameter. The column with the path can then help you know where the other module is that is using the data from the module who's references you're looking at. I us this when I'm going to delete or heavily modify a module to see what other modules are getting data from it so I can edit those modules as well. Usually a bigger deal when you're going to delete a module. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
